NEW S5 does cancel Print Job immediately
Desprinzla
Posted · NEW S5 does cancel Print Job immediately
Dear all, this is my first Thread as new owner of S5 Pro Bundle,
when I start a print job, regardless of whether it is from the cloud or a USB stick, the printer stops immediately and says the print job is finished.
Why is that, especially since I've been printing permanently for the last 10 days.
Since just now, as soon as I want to start a print job, the waiting circle on the display starts to rotate, rotates 360 ° and says done! even though he hasn't even started printing.
Also when staring at an XY offset calibration, the same thing. he turns the waiting clock once and says done.
I've only had this since I had to reset everything to the factory settings because a print job was in nirvana as a continuous loop.
Who can help me here ?
lg Giudo
    Did you look at your part in PREVIEW mode in the slicer?  That will let you know if there is anything to print.  There could be a problem with your model (for example walls too thin) where there is actually nothing that can be printed with the current Cura settings.
    yes this is all ok, also i did print this part before, as suggested from Torgeir in Tread below i disabled the Material Station and now it works.
    So you think its an Problem with the Material Station???? ot the connection?
    even though i had new Firmware i did update it with same 6.1.1 Firmware and it works. All solved
