There are 2 common things that can be crooked. The entire frame. Or just the cross bars through the head. First check the two bars through the head for perpendicularity. I usually assume the frame is fine and just push the head to the center of each of 4 sides and check that the blocks are hitting all at the same time. If not loosen a set screw and make the 2 bars perpendicular.
However if your printer landed on one of the 4 vertical corners (or a true corner) it may now be out of square (the gantry). Some people have just put tons of weight on the printer to get it back in square. I've never had to fix this but if it were me I would loosen all the screws first and try to shove it back into square. Sometimes people purchase just the top plate of the printer to get the gantry square again. You can get any part of the printer by contacting your reseller. If you don't know who your reseller is then you can just contact one of the bigger sellers in your area.
You could also write a post processing plugin extension if you know how to write code. They are in python and there are example ones you can start with. You could add a little bit to every Y position depending on the X position (or vice versa). Something like y+= x/200*0.3 (over 200mm course of X, add 0.3mm - linearly).
On April 20 - April 23 we will host the Ultimaker Transformation Summit. Come talk to us via Live chat and get inspired by any of our relevant presentations!
gr5 1,606
gr5 1,606
