Thank you for your answer.
I believe there is no mistake in my printer settings. My printer center is 0,0
When origin at center checked, expected behavior is when you move the object y-20 on gui, gcode output also move the object y-20.
from my understanding its a bug right?
Edited by onr
gr5 1,606
Y=-20 means 20mm left of center of your printer. however...
For some reason, Cura thinks you have a delta printer. But I'm sure you don't.
Go to left side of screen in PREPARE mode. Click on your printer, then do "manage printers" then "machine settings", Uncheck "origin at center". That will fix it so it prints in the center of your printer instead of the front left corner.
