Thanks I will look into that. I was also guessing was something along those lines, but wasn't sure where to begin.... there are so many different settings that could tie into that. We definitely need the high layer adhesion these will be working parts that we hope to spin at 3600 RPM.
geert_2 557
I am going to do some wild guessing: could this be a result of high pressure in the nozzle, after printing infill at high speed and temp, and then suddenly slowing down to the outer layer. Thus the built-up pressure and temperature has to leak away, sort of? Or a result of a move through the air, where it temporary stops extruding, with the same effect? Or both together?
If the first, then setting all speeds and temps equal should minimise this effect. If the second, printing slower and cooler should minimise it (but printing cooler of course might reduce layer bonding).
But as said, this is guessing.
