I checked with the Arachne Beta but it happens there as well. Same result shown in the screenshots.
All the walls are 2mm in thickness and the connectors between the hexagons are 1mm in thickness and 2mm high. And it gets correctly sliced at the second layer and on. Only 1 layer too high.
What baffles me the most is that it does it even when submerging the model well under the bed. I deactivated "Drop model to buildplate" and lowered it to -1mm and the layer view showed the same image as in the screenshots but naturally only for 4 layers instead of 8.
Maybe as a sidenote: this also happens when no support are generated.
I attached the STL, maybe so we can rule out a general error and that it's only on my side or not.
If necessary I can also provide the F3D or the OBJ file.
nallath 1,120
I think the features that you are trying to slice might be a bit too thin. Could you check it with the Beta release of Arachne?
