Greg is really quick, as usual.
I see exactly this too ..
No problem.. 🤔
No problem.. 🤔
I have to be because you get up 5 hours ahead of me🙃.
Within each of the last 7 layers at the end of the Gcode file there should be a comment line ";TYPE:SKIN" that indicates the upcoming code will do a top layer. Check the file on the SD card for that. Some times the card can get funky and the end of a gcode file gets cut off as it gets written into a bad sector. You can try re-formatting the SD card, copying the file back to it and printing again.
Ha`! Mr. Natural Icon?
I see the layers in the Gcode as you say. But what am I seeing in the simulation then? Maybe I am misinterpreting the "mesh" looking appearance and this is indeed the top layer? I though there was a colour option to control the appearance but maybe I am thinking of fusion.
Thanks!
Fritz
When you get a moment put up a screen shot of what you are seeing. Make it with the preview slider on the topmost layer.
And yes, it's Mr. Natural. You're the first to comment. I think because nobody else wanted to admit they were old enough to remember.
Here is a shot of the test model. The top is layer 83 of 83 and the six below it are the same.
1 outer wall, 2 inner walls, 1 extra skin wall, then the skin at 45°.
Edited by GregValiant
Heck-I grew up with Big Daddy Garlits and the Rat Fink too!
Regarding your screen shot---I played with the color and got about the same thing so I will spare you the image. I guess I am OK then---I thought the cross hatches on the top were symbolizing an Infill layer but I guess it means "Top" layer. I will get to the lab and do another print to see how it goes.
Your help was really appreciated!
Keep on Truck'n
Fritz
GregValiant 255
When I slice that 3mf I get 7 layers on top and 7 layers on the bottom. The total layers is 83. Using the Cura mesh checker the model is fine.
So from here I don't see a problem either with the model or with the Cura settings.
