There is a one layer gap between support interface and next model layer
Rivanov
Posted · There is a one layer gap between support interface and next model layer
I tried to improve the first layer above the support. I found an interface setting in the support section of the settings. There is a gap between the top support interface layer and the next model layer. I cannot find a solution to control this gap. I want to be less than one layer, for example, to be 0.1mm. There is the attached shot of my problem.
Would you help me?
    You can set the gap to anything you want but I think it will be moved to the nearest layer.  I don't think you can do support on in-between layers without changing the vertical resolution (e.g. .06 layer height).
