Hello!
The model is on thingiverse here
(STL attached)
The Author had a special version for 1mm nozzles. I've since tried 2 things. Turned off Spiralize, And was told to turn on PRINT THIN WALLS under SHELL. Still looks crappy.
I wanted to print those beautiful Spiral vases with transparent filament with the Thick layer lines. I'm surer you've seen that.
GregValiant 1,251
If you will post the STL somebody will take a look. Guessing from the image it looks like a problem with the model.
Is that model solid through and through or is it hollow with a thin wall?
