Thanks. When I checked this option, the check marks were already there. I guess I might have checked them few months ago. If I use adaptive layers, do values in Quality->Layer Height and Initial Layer Height have an effect on the prints? If I want only the first layer to be 0.2mm but the rest to start to have lower adaptive layers, what shall I do?
Besides this function, that what else can I do to make the prints smooth?
Edited by ultimaker_user
Torgeir 172
Hi @ultimaker_user,
"use adaptive layers" is not set by default, you need to select it yourself.
Go to "preferences", then select settings and then select; "check all". Close preferences.
Next, select "printer settings" go to "experimental" and select; "use adaptive layers".
That's all.
Thanks
Torgeir
Edited by TorgeirMore text.
