I have the same problem, my resolve is I 20x all models in Blender then 1/2 them once I've imported them into Cura. What that does is it takes a 10 Meter cube in Blender to a 10 Millimeter cube in Cura.
- 2 weeks later...
A new version of the Mesh Tools plugin is now available in the Marketplace, which lets you set a unit for STL, OBJ and PLY files:
Thanks
Up and running now
- 1 year later...
not sure if this helps but I find that when exporting the default cube to stl, if you change the scale in the export menu to 5, your cube will be exactly 1 centimeter in cura
nallath 1,124
Cura expects units to be mm. STL doesn't define units, so cura just makes a guess what you mean if the model is too small or too big.
Cura is metric only. There is a plugin to convert from inches to mm, but thats it.
