Just as a first simple thing to check. Make sure the cables that go into the heated bed are securely held in place.
Hi thanks for the reply - nothing appears to be loose. The odd thing is that often a simple abort cures the problem.
Several people had a cold solder joint where the 4 heated bed wires are soldered in. The joint can have a crack so tiny that you can't see it. I recommend heating up all 4 - or at least the 2 big wire ones.
See this first:
http://umforum.ultimaker.com/index.php?/topic/3735-a-fix-for-ultimaker-2-heated-bed-not-working/
And this photo also:
OK many thanks, will take a look. Did several small print runs last night and everything seemed to be fine but guess it would not hurt to check.
Thanks
Update on the printer bed.
I took the bed apart and discovered that one of the retaining screws was a little loose, so it seems the action of me pressing the abort button and possibly moving the unit may have been the reason it appeared to solve the problem.
Tightening up all the screws has solved the problem.
Thanks as always for the great advice.
IRobertI 503
