Please post your project file - do "file" "save project as..." and post that file. It will include your model and ALL of your settings (including machine settings).
Is the problem you are seeing only happening on the bottom layer? It might be that the model needs to be moved up or down very very slightly.
Tinkercad usually does a pretty good job of making manifold objects (some cad programs like sketchup and blender - not so much). It might not be your CAD. Let's look at your model first.
GregValiant 955
PrusaSlicer and Cura handle models with errors differently. I'm not positive but it appears that PrusaSlicer automatically repairs a model and then slices it. Cura should inform the user that the model has errors. TinkerCad is well known for leaving faces that are backwards and that causes slicing errors that turn into print errors. "Automatic Repair" is an option in the IdeaMaker slicer but not in Cura.
@gr5 will know how to fix it in TinkerCad.
In the meantime if you go to Service.Netfabb.com and create a free AutoDesk account, you can upload that STL file, it will be repaired, and then you can download the fixed file.
Edited by GregValiantLink to post
fysis88 0
Greg , thank you for your response.
Netfabb did not resolve my problem , nor any other similar website or software that repairs STLs . Not even IdeaMaker.
I dont know what to do..
Maybe i should just learn how to design in Fusion360.. 😞
