1 minute ago, Enigma_M4 said:moving past the Z end stop (lowering the bed to much) would normally result in to much space between print bed and printhead at start of print.
Your problem may result in the bed stopping before the Z end stop is reached.
So you should check the small pit where the Z end switch is located for debries blocking the Z switch.
Regards
If the machine tries to go past the bottom of the Z travel then the head to bed distance is shorter than the controller thinks, and it crashes the nozzle into the bed.
The bed is homing correctly during other operations, including print completion and automatic leveling.
Enigma_M4 101
it sounds a bit confusion, as moving past the Z end stop (lowering the bed to much) would normally result in to much space between print bed and printhead at start of print.
Regards
