By the way, all resellers have the ability to sell you any part in any Ultimaker printer. But because there are thousands of parts (many thousands maybe?) and because it's complicated (sometimes a part is only compatible with printers of a certain serial number range) and prices change, you will not find them on their webstore. You have to email or call them.
gr5 1,968
This is called the lift switch. It is broken - not repairable.
Contact your reseller. Give them your serial number and tell them "the lift switch broke". You have many options:
1) You can send the whole printer to them - this is likely expensive and printers are easily damaged in transportation but this is a good option if you have lots of money.
2) You can have them send you the necessary parts and you can fix it yourself. If it's under warranty this is free. If not this is still very little money (compared to the cost of filament). There are very well written instructions with lots of pictures showing you how to take apart the print head and reassemble it. It's really not hard - it's not like an iphone that is glued together - everything in these printers comes apart easily. Easy to fix.
(option 2 is two options as one involves warranty and one does not)
3) You can turn this into a single extruder printer. I don't recommend this option but there *is* a way to disable the active level. It involves hacking the firmware but I know people who have done it and I have the instructions somewhere. Not recommended. Plus you will have to redo the hack each time firmware is updated.
Option 2a or 2b is best.
