20 hours ago, GregValiant said:How wide is the line?
How thick is each stencil?
What material do you anticipate using?
Greg, I am not locked in on dimensions at this stage, probably to start with will take 0.8 nozel and layer height 0.8 as well. The x and y axix can vary depending on the content. Once successful will narrow down to smaller sizes. Thanks!
nallath 1,124
Maybe you can get that to work with the SVG toolpath plugin. I've not worked with that myself, but i've seen people do some pretty crazy things with that.
GregValiant 1,330
amitmonash 2
Thanks Nallath, that is very close to what I am looking for. All I need to do now is to figure out z axis. Should be able to test out when I get my printer.
