STL File of the #2137 Clamp Clip
Posted · STL File of the #2137 Clamp Clip
not exactly, but there are a lot of versions online at Youmagine or Thingiverse.
For example:
https://www.youmagine.com/designs/easy-clips-for-ultimaker
https://www.youmagine.com/designs/ultimaker2-bowden-cable-clip
https://www.youmagine.com/designs/ultimaker-2-bowden-clip
https://www.youmagine.com/designs/ultimaker-bowden-holder-clip
Regards
    8 hours ago, Erick_98 said:
    Hi! Does anyone has an sTL file of this part? Is the #2137 CLAMP CLIP. Thanks!
    Well, the step file is published on GitHub:
    https://github.com/Ultimaker/Ultimaker3/tree/master/2137/2137-A
    If you want exactly this part - just convert it to stl format. A convenient way is:
    https://www.opencascade.com/products/cad-assistant/
    2137-A.stl
