I already got a new set through warranty - collet and bowden. But after some time the problem came up again. On one hand I would doubt, that I would get a second warranty replacement and secondly it would not help after the end of warranty. So I did a deep dive problem identification and found, that it always happens when printing a long time with many short movements of the print head. The solution is, aside from replacing the colletm, to longen the short tube, where the collet is placed in, on top of the feeder. So the movement is no longer this hard. By the way, it only shows up on the left feeder (looking from front), the right one never showed this behaviour.
Any rewards for improvement proposals?
Edited by ndimensionalTypo
ndimensional 7
I had the same problem. I created a bowden support, so that the bowden is not moving at the outlet of the feeder. I own an S3, so I do not know if the support will work with your model. It is a bit tight at the right side with the lever, but it does the job for me. I created it with FreeCAD, so feel free to adjust to your needs.
To apply you have to remove the bowden and insert it into the tube part on top. Then reattach the bowden and finally slide the part over the feeder.
The movement of the bowden, especially when doing tiny zigzag lines is slowly loosening the bowden and then the pressure from the feeder and material is pushing it out of its hold. At least this is my diagnosis.
UMS3.zip
Smithy 1,145
It sounds like you have a faulty collet in your printer. When the blades are too short, they cannot grab correctly into the Bowden and then it happens that the Bowden gets loose. I had the some problem on one of my printers, happened several times and after I changes the little piece, it is ok again.
Contact your reseller to get a new one. You can replace it easily, no need to open the feeder, just pull it out and put the new one in.
