The IDEX system won't work with 4.9.1 (or well, any version of Cura released by Ultimaker). BCN3D hacked that into their version and I think that's why they don't update.
24 minutes ago, nallath said:The IDEX system won't work with 4.9.1 (or well, any version of Cura released by Ultimaker). BCN3D hacked that into their version and I think that's why they don't update.
Thanks Nallath !
I was suspecting the IDEX system to be a showstopper.
GregValiant 1,488
And now I know.
GregValiant 1,488
The Sovol SV02 and the Tevo Tarantula Pro are dual extruder machines. If you were to install one of them (with the name of your choice), and then go to Manage Printers and Machine Settings you may be able to make adjustments to the printer settings (build plate size, heated volume, gcode flavor, start and end gcode, Extruder settings, etc.) and get it to work. Hopefully someone else will chip in if they know of a better or less clumsy way to do it.
You might be able to use the Ultimaker S5 definition but I don't know those machines or whether it would be possible to alter one to suit.
