GregValiant 1,330
That's correct. At this time Cura does not interpret G2/G3 commands in the preview. I think that's being looked at and will be fixed.
@BStump is it possible for you to post the 3mf file and the gcode file? Somebody will take a look. As far as I know, "One at a time" isn't interfered with by any other setting.
Bill_D 0
I can't comment on the 'one part at a time' issue. But I just experienced the same issue with an "Arcwelded" G-code not showing correctly in the Cura preview. That part is printing as I write this with no problems, so I have to assume that Cura does not recognize G2/G3 commands and just previews them as straight lines.
A side effect of that is that now I can see where the G2/G3 commands show up in the layer.
Edited by Bill_DLink to post
