How to add translation for third party plugins
frankpian
Posted · How to add translation for third party plugins
I'm a Cura plugin developer.I want to use "UM. I18n" to finish this job.Do I have to put the translation file in the "resources/i18n" directory?
I hope to find some examples. Thanks!
    4 minutes ago, nallath said:
    Uh. Yes that should work.
    So, the translation file cannot be published with the plugin, but should be submitted to the Cura mainline code?
    Your QML file must import UM 1.1 as UM, and then include UM.I18nCatalog{id: catalog; name: "cura"} as a child of something Item-like.
    Oh yes, thank you very much
        • 27 replies
