The printer has been on hiatus for a while...I installed 4.9 and have the same crash problem with it as well. Thought I would try to fix the crash issue on one that used to work before I risked all of my custom print profiles and settings.
You can just make a backup and try the new version.
Cura versions should also just work side by side.
Just make sure you read the dialogs of the installer of the newer version!
You don't have to let the installer uninstall the previous version.
1
I backed up my original files and did an uninstall of all versions on my PC, downloaded and installed 4.9.1 then restarted. First try the app opened OK and didn't show any previous files to open so I tried File Open, same crash issue. I will try again when I get back to my PC and post the log and error files.
Tried to run the new 4.9.1 install again and it will open correctly and all of the drop downs, and zoom-pan-rotate functions work but it is still crashing when I try to open a file. Click File Open and the File Open (Explorer) window still opens for a few seconds with the "waiting" spinner for a few then everything closes. NO Admin or Compatibility Mode this time, just installed it (AV off during install only) and ran. Help please
@MarshSt do you maybe have also Chitubox installed?
No I do not have Chitubox installed. The only change I made was upgrading from Win7 Pro to Win10 Pro. There was a pretty long span of time between my using it on Win7 and me trying to use it on Win10.
I think I have it solved, found this on Github. I have a Dell laptop and it had Dell backup and Restore from new, uninstalled it and now Cura is working fine. Thanks for the help.
"NOTE: If you have a Dell Laptop/PC, this may be useful information or something to at least look at trying. We had this same crash issue when opening/saving files on my wife's Dell laptop with Cura ver. 4.1.0 and even the latest 4.2.1 -- see Cura Git issue #4220 for more specific details.
The issue was fixed after disabling 3 Dell Backup & Restore Shell Extension services (used Nirsoft's shexview.exe). Here are 2 of 3 disabled:
DBROverlayIconBackuped.DBROverlayIconBackuped
and
DBROverlayIconNotBackuped.DBROverlayIconNotBackuped
The third (disabling may not have been needed) but it was named something very similarly and likely related, so I went ahead and disabled it as well."
nallath 1,117
Cura 3.2? That's a blast from the past. Is there any reason you didn't upgrade to a newer vesion?
