Hi geert_2,
as one can see in the image some parts are printed clearly without any blobs and some parts not.
So I doubt that it is a problem of overextrusion since then overall there would be more filament and not only where the blobs are.
The nozzle is not too close, I recalibrated the printbed with a sheet of paper and again, since parts are printed well it could not be the nozzle too close to the printbed.
The polygons are very simple big squares and triangles almost bigger than 4 cm!
So there must be another reason for those blobs. The only appear on the first layer.
Any further ideas?
geert_2 556
There might be lots of reasons for blobs: overextrusion (for whatever reason); the nozzle being too close to the bed (also resulting in a sort of overextrusion-effect); a too fine STL-file with way too much polygons which slows down the printer; material accumulating on the outside of the nozzle, and then being dropped onto the print; and probably other reasons that I don't think of at this moment.
I would suggest that you watch very closely while printing, maybe use a magnifying glass: most of the time you will see what happens, or you can narrow down the causes.
