Hi Bernard.
There was a problem with Cura detecting the inner wall.
So I made this sphere in Fusion 360 (Autocad free version) Just 20 mm diameter and strait hole dia. 8 mm.
The wall gradually increased from approx 70 deg. (0.4 mm to top 0.8 mm) and same at the bottom.
Seems to be possible to print, but not sure how it will be.
Here is a picture how it's looking in Cura Arachne Beta.
Here's the your project file from Cura Arachne Beta;
CFFFP_Sphere_Exp_Arachne_B_0_2mm.3mf
And the gcode, but have not checked this one..
CFFFP_Sphere_Exp_Arachne_B_0_2mm.gcode
Torgeir
JaXXoN 0
Hi Torgeir,
Thanks very much for your detailed answer. Highly appreciate it!
I'd like to avoid 0.1mm height or otherwise printing the model will take ages (it already does with 0.2mm).
For fixing the hole on the top, I can add another overlay. Please see attached screenshot and Cura project file (don't worry about overhangs/support, that's a separate issue I can tackle).
My concern is that there is no smooth transition between the surface mode area and the overlay areas (please see other attached screenshot)
Feedback is highly appreciated!
TIA and best regards
Bernhard
PS.: The Airframe I intend to print has a length of around 90 cm and a wingspan of of around 90 cm. So just to get a felling on how things will print (flat/upright) I simply created 1x1x1m printer for early inspection 🙂
I certainly need to cut the airframe in pieces for printing on my CR10S4 - and that's what most of the fuzz is about: simply exporting cut parts of the model will introduce additional walls I don't want. Surface mode helps in this respect, but obviously introduces new challanges ...
SphereWith2HolesBottomAndTop.3mf
Edited by JaXXoNRemoved inline-images because they somehow messed up the formatting
