This works on a PC but not (anymore) on Mac, not even with an older version.
So any solution yet?
This is (probably) a macOS-specific bug in the Qt GUI framework that Cura uses. It is likely fixed in the Qt version that will be used in the next version of Cura (Cura 5).
geert_2 543
I my (different) Cura-version this worked.
Maybe try a couple of different pictures, to find out whether it is a Cura-issue, settings-issue, or a defect in the file?
