GregValiant 1,116
If you designed the part in inches then select the model and set the scale to 2540%. You could scale the model up in the cad software just so you could export it but I've always found that to be an unnecessary step. It really doesn't matter so long as you know the conversion factor whether it's from decimal feet to millimeters or whatever.
Smithy 1,141
You can configure Cura in the application preferences if you want to scale very small models and/or very large models. If I remember correctly the checkbox to scale very small models is checked by default. So you can just disable that.
