I've attempted to contact them. I was wondering if it was with the cura code that I was having trouble with.
The gcode that Cura comes up with is pretty generic at the start. Heat the bed, heat the hot end, Auto-Home, start printing.
If there is something that Xvico put into the startup gcode, or into their firmware, then they need to explain it to you.
I can't make any promises but if you post the gcode file I can take a look. If you received a sample file on the SD card that came with the printer - does the sample work OK?
nallath 1,123
Maybe it's best to contact xvico3d if you have specific issues. I don't think that anyone here has that specific printer, so it will be almost impossible for people to help you with printer specific issues.
