Thank you for the answers!
I have suggested this feature, because actually the lift switch of the printer that I'm using is not working properly. The printer cannot switch nozzles, so the active leveling fails. Recalibration of the lift switch positioning didn't help either.
Workaround was to set automatic leveling frequency to 'never' and do a manual leveling. Nevertheless, I would suggest to implement one of the following solutions
1. remove the second extruder and circumvent the switching issue in this way or
2. manually act on the lift switch to set the active extruder before printing and let the printer know that it should not use both extruders during automatic leveling and printing
Another idea was that the printer could make use of the camera to detect if the lift switch works properly during automatic leveling and inform the user about this, giving instructions to make printing possible even though the problem persists.
Smithy 1,134
I don't think it will come, because I read somewhere that it is important for the print core cooling (airflow) to have both print cores installed. And the printer comes with 3 print cores, so you have to loose 2 of them to get into this situation.
nallath 1,101
Correct. With only a single core it causes a whole bunch of problems.
