Posted · Ultimaker 3 Switching off suddenly
Hello,
Coming back from hollidays, I launched a print on my ultimaker 3, which was working perfectly before.
After clicking on my print, the head went at right to lift the second nozzle. Then it moved a bit to the center and STOP. The printer switched off and rebooted. And this each time.
So I updated the firmware from 4.3 to 4.9. Still switching off. Then I updated from 4.9 to 5.2 (latest). Once I put myself the head in the middle before switching ON the printer.
Now it is switching off at the very beginning of the printing, when it says" nozzle heating".
I noticed that the 2 nozzles were heating, which shouldn't be.
One old print worked when I went to print settings and that I lowered the bed temperature, strange.
I join the STL and gcode files of one print for analyse.
I did all the diagnostic tests in the maintenance part and all is ok.
Thanks for solutions.
0,4Socle photodiodeU3.gcode Socle photodiode.STL
  • 1 month later...
it sounds like a power supply problem indeed, do you use any 3d party printcores?
You could try setting the initial temperature for the 2nd hotend to 0
Otherwise you could edit the /usr/share/griffin/griffin/machines/um3.json and set the total_power_budget to be a bit lower. This could Nerf your machine though, heating could take longer.
(to do this last step you need dev mode active and either user ssh or use winscp)
    I use original printcores.
    I tried manually different steps:
    Printcore 1 at 250°C: OK (then come back to ambiant temperature)
    Printocre 2 at 250°C: OK  (then come back to ambiant temperature)
    Bed at 60°C: OK
    Print core 1 250°C + BED 60°: OK
    Print core 1 250°C + BED 60° + printcore 2 250°: STOP and REBOOT
    I came back to only BED at 60°: directly STOP and REBOOT, the same several times (it didn't happen the first time).
    I didn't connect in SSH mode yet. I need to see how to do it.
    You can see logfile (after printing crashes) attached and the videos of booting and crash here: https://we.tl/t-28wmA78aa2
    dmesg.log
