Posted (edited) · 3MF Import Error
Hello, I have started using 3MF files from Solidworks to use with Cura, rather than the STL file format. The issue is that when I drag and drop a 3MF file into Cura, it places the solidworks parts' coordinate system at the (0,0,0) location instead of at the center of the bed. I am not sure how to get the 3MF file to be loaded to the center of the bed just like the stl file does. I have attached pictures for reference. I should note that I already tried changing the 3MF export coordinate system in the SW export settings window but that did nothing.
Edited by sol095
    • 5 weeks later...
    • 4 weeks later...
    • 3 weeks later...
    Posted · 3MF Import Error
    Thanks for this, changing it to 0,0 wasn't that much effort, but Ctrl+R is much easier.
    It would be good if there was an option to Ctrl+R (Arrange all models) by default when importing 3MF files and ignore its own origin.
