fbrc8-erin 283
3 hours ago, jpdrude said:Wow, I didn't run past this information before. It seems, that it is actually the front fan, that is causing the problem. Thats a connection, I'd have never made on my own. Thank you so much. A replacement part is already on the way.
The fan thing took a bit to diagnose as a potential cause for the issue when we first came across it--but the good news is, it's one of the easiest things to test for and definitively rule out ones you are looking for it.
- 1
Smithy 1,144
Check these two articles, maybe it helps:
https://support.ultimaker.com/hc/en-us/articles/360011576000-ER45-Capacitive-sensor-low-performance-or-interference-detected
https://ultimakernasupport.zendesk.com/hc/en-us/articles/115005705806-Why-Isn-t-My-Active-Leveling-Working-
jpdrude 0
