What could cause these patterns in the print? Using eSun PLA+
Posted
· What could cause these patterns in the print? Using eSun PLA+
@monomonster, this looks like the 3d printing defect known as ringing. It is generally caused by vibrations that come from the moving components of a printer. Belts that are too loose are a common cause. Does this happen on both the X and Y oriented faces, or just one or the other? A high print speed can also cause this to happen more often, since direction changes become more harsh.
I print a couple of eSun PLA+ spools per week on S5 pro bundles, and have had very good results, although I am printing functional parts where dimensional accuracy is the primary focus, not looks. I typically print at 215C because I am in need of fast print times (typically 70-90mm/s), and I do see some ringing in my prints due to high speed.
If I were going for looks I would probably set the speed at 50mm/s with outer wall speed set to 25-30 mm/s. This can feel quite slow if you are used to printing at higher speeds, but should be worth the wait when it comes to x/y surface quality.
Posted
What if you try a slightly different speed? Could this be vibrations (e.g. from the steppers or the belt-teeth) that are fed through to the print-head, combined with resonance?
FRabe 5
