GregValiant 951
I was going to take a look. My computer isn't beefy enough to open that in any software.
Mine (9900k, 32gigs of ram) opens it (takes a moment to load) but chokes around 90% of autoslice. Mesh tools shows a warning that the model may not be watertight. Disabled auto-slice, tried to fix the normals but that just locks up cura on my end. Sorry. That's one big-ass litho lol.
Prusa opens it relatively quick but shows 79849 auto-repaired errors. That's probably why it won't slice. Huge non-manifold model
Edited by Ch3vr0n5 hours ago, Ch3vr0n said:Prusa opens it relatively quick but shows 79849 auto-repaired errors. That's probably why it won't slice. Huge non-manifold model
Thank you.
This is a good hint. I will try something...
Here's the prusa repaired one. https://drive.google.com/file/d/1TYvvdlfJzwtyAFlfCGtmk2jRVsbb6aGP/view?usp=sharing I couldn't get it to upload here. Took too long. I'll tinker with it some more on my end.
- 1 year later...
On 8/26/2021 at 4:27 PM, Sifon said:And here is .stl.....maybe 🙂
How did you manage to slice it
I also has a stl of more than 900MB and same issue
Hey @JeremiaL,
Welcome to the Ultimaker Community 🎉
Wow! I'm super curious what you are trying to print. 🔍
You can try a more elaborate mesh fixer like https://myminifactory.github.io/Fast-Quadric-Mesh-Simplification/.
You will lose some of the detail but I bet that you 3D printer wouldn't have been able to pick it up anyways.
Good luck 💪
fvrmr 73
Hi @Sifon could you share your project file (file - save project) and log file? You can find your log here: $HOME/Library/Application Support/cura/<Cura version>/cura.log
