On 8/28/2021 at 11:10 AM, emphyrio said:1) Nothing states what this plugin is supposed to backup. Seetings? Plugins? Everything?
Everything. It also states what it will save if you actually do the backup (and shows how many things it will restore if you open a backup
On 8/28/2021 at 11:10 AM, emphyrio said:2) More important: where are the backup files stored? Impossible to find them on my computer.
They are stored remotely. That is also why you need to login before you can use the plugin.
Smithy 1,134
You can just copy the configuration folder to the new computer and you should have everything as before.
The location of the configuration folder can be found when you go to the HELP menu, there is an entry for the configuration folder.
nallath 1,101
Or even easier; Make a backup with the builtin backup plugin. You can find it under extensions.
emphyrio 0
@Smithy: thank you, that's exactly what I was looking for. I must admit that I didn't see this option.
@nallath: thank you also.
I saw this plugin, but:
Many thanks!
