Hi @JTMD, I'm sorry to hear you are having such difficulties setting up a reliable workflow. I think we'd be able to be of more help if you would be able to elaborate a little bit more on why you can't seem to have good prints besides with Ultimaker filament, and what you mean with the print core jamming issue.
Without knowing what is not good about non-Ultimaker filament prints, it is hard to give any tips. If a model comes out great with one filament (Ultimaker?) but less with another (non-Ultimaker?), it would be easy to suspect the print profile. If you have any feedback we can evaluate and see if we can improve on the profile if necessary!
A few ideas: a clogged print core can happen when the front fan isn't working. This can be because the cable is loose, the cable got pinched or because there are tiny strings of filament preventing the blades from spinning.
Loose cable: The fan is never working and there is nothing blocking the blades.
Pinched cable: This can be visually inspected, it should be around the print head fan bracket that can open and close.
Blocked fan: It shouldn't work, and you should be able to visually see some small strings of filament, can be quite thin. By removing them it should work again.
Regarding the appears to be empty message:
Do you get it with any filament, or one in particular you are trying to print with?
If you get the message that a spool appears to be empty, that can be when a print core starts to clog and it can not extrude anymore, so perhaps these are related.
Regarding the firewall, I don't think this will/should be enabled by default, but it can be toggled on/off via the menu. Perhaps you enabled it without noticing while scrolling through the menu. Happy you found out that it was turned on. If you are curious to read about what protection the firewall gives and what data it blocks, we have a support article about it.
Hope this helps!
JTMD 19
UPDATE!! got the network issue solved - firewall was enabled. now, since I just now found out it had a firewall, I gotta believe that happened when I updated the firmware....
Now, back to the print core jamming issue....
