Regarding gcode flavor, if you use the ultimaker2 flavor then you can control retraction live while it's printing and experiment. You can do this in the TUNE menu. You can also create a custom filament type on the printer (e.g. TPU95) and it can have custom settings for a few things including retraction distance (and speed I think?), nozzle temp, bed temp, fan speed.
I actually have a few parts that I print a lot in 2 different materials (nGen and PLA) but I only have one gcode file for both as I select the material on the printer.
gr5 2,094
So what is the problem? Is it stringing too much (you mentioned retraction a lot which helps prevent stringing). Or is it underextruding? (underextrusion is the most common problem with soft filaments) Or does printing fail completely? (also common with soft filaments - the filament can get crumpled up in the feeder).
Regarding "too much support", look into "support blocker" feature of cura. There are great videos on youtube and other explanations if you google how to use the support blocker feature. It makes it very easy to block support in any one spot of your model.
