Ticking that box seems to have fixed the issue
If this ever happens again, instead of using your custom "LXEU-UMS3" machine settings, you could add another generic S3 printer (you can have as many as you want) and then you can compare your custom S3 to the default S3 settings. In fact you might want to do that anyway and see if anything else changed.
1
HoB 0
I did an relative dual extruder calibration very recently. Is it possible there is a software bug that automatically changed the printer settings / unticks the "Apply Extruder Offset to GCode" box automatically?
