same here... what do you do with the fuzz collector ??
Ian :-)
Ian :-)
I would imagine the fuzz roller is to clean all the bits off the inside of the machine.
I use a folded over piece of gaffa tape to pick up all the waste that collects under the bed.
For getting a large print off the bed without stressing any delicate parts, I recommend a strong but thin edged spatula like this.
Nice idea - I use (as Ian too as I remember) a nice big knife for removing things...
Reg. the roller: to clean the print surface with it might be worth trying...
Hi guys,
Thank you that you join in. Please continue to show your little ideas, even if you might think it's nothing special.
Yes, the sheets of lint roller does not stick as much, but this is almost always enough to collect loose filament cord, and other particles. In my picture is a bit exaggerated displayed that I had just made the interior clean.
Markus
I use one of my wife's old crochet hooks to remove the stray bits of blobbing and stringing that might ruin a print while still printing. I suppose a button hook would work too.
THAT´s a great idea... I´m always struggling with a pair of needle pliers trying to remove the ooze...
For string removal I like to use tweezers. Normally I use these when soldering but they work great on the printer as well I mostly use the curved one as it's easier to reach under the nozzle that way.
I have a few of them at home and no idea what to do after iPhone repair - ans you get always a new set if you purchase spare parts for the apple stuff. That´s a great idea for using this parts especially with small prints which might be damaged by using a BIIIGGG knife...
Silence here?
But this is real pity.
Who often has to disassemble the material feeder, which has certainly been annoyed about the following:
The motor tilts back against the cover, and the fitting of the four screws in the engine is to be patient exercise.
Maybe the last time you take the cover off and stuck a pair of rubber buffer to the motor. Then the engine will remain in position without screws.
Markus
Here's another possibility, with more force to keep the Bowden tube in position. :cool:
Seeking small O-rings, or comparable distance pieces with appropriate diameter for the neck of the couplings.
Mario, the plumber has the right material possibly. :mrgreen:
You can of course ask Luigi ... :oops:
I think you could even carry the entire printer on Bowden after this little optimization.
Beware of elephant proboscis...
Markus
Small preparations for a recalibration of the printing platform:
Sometimes a small residue left on the nozzle, which interferes with a proper re-calibration of the printing platform. Without reading glasses I have it sometimes hard to recognize this immediately.
Tip:
It helps if you use the "Move material" function.
1) Wait until the nozzle on the basis of: "Move material" function; was heated.
2) A small amount of material with the help of the "adjustment wheel", move out.
3) With the function "Heatup nozzle"; monitor the cooling process of the nozzle.
4) Wait until the extrusion is cooled down to about 135 degrees.
5) Now drag the visible residue with your fingers from the nozzle.
Done, now no more residual material should be present at the nozzle.
Markus
drayson 74
Nice ideas, especially the pipe cleaner (will work on my UM1 too)... but I have no idea what to do with the Fusselroller...?
