It’s just a visual effect
16 minutes ago, nallath said:Can you also feel the infill through the walls or is it just a visual effect?
in that case Ithink your only option is to increase the number of walls
42 minutes ago, nallath said:in that case Ithink your only option is to increase the number of walls
Ok but I already have a wall thick mess of 1.6 and have 4 walls
43 minutes ago, nallath said:in that case Ithink your only option is to increase the number of walls
It also depends on the kind of material/filament you use. Some brands are a bit translucent and then you see more infill. As nallath said, increase the walls and you should be fine.
3 minutes ago, Smithy said:It also depends on the kind of material/filament you use. Some brands are a bit translucent and then you see more infill. As nallath said, increase the walls and you should be fine.
Ok thank you
nallath 1,123
