tinkergnome 918
1 hour ago, Smithy said:I hardly believe that it is bundled with the official Ultimaker Cura version, or is it really?
It actually is... (a version from 2019):
https://github.com/Ultimaker/cura-binary-data/commit/a061ffec6ae516a202e0a7aba2ffb2f5c7353f77
I guess that's what @ChiefSwiftnick is talking about.
1
GregValiant 741
I'm very surprised by that. Perplexed as well. Time to use the strike through font and my apologies to all.
Yes it is bundled in the official version.
The firmware is fine for older machines, but recent machines have a different front panel that uses a slightly different firmware. Lesser experienced users have seen the upgrade firmware button in Cura and just pressed it not knowing what is actually being installed. As a result the front panel stops working, rendering their machine unusable.
Firmware for both versions is available and Marlin builds from 2.0.7 will detect and work with both panels. This is not official Anycubic firmware though.
So I guess the options are:
1) Remove the hex file
2) Add machine profiles for new and old Chirons (with the corresponding Hex file)
3) Add a later version of Marlin that supports both panel types. (I can do a PR with a new Hex file)
4) Add a warning to check machine build before upgrading
Just my 2p's worth!
Nick
Smithy 1,090
You are talking about that Cura has a firmware bundled for the Anycubic printer?
If so, I hardly believe that it is bundled with the official Ultimaker Cura version, or is it really?
