Dim3nsioneer 557
To be a special case is not necessarily a bad thing... :wink:
A relatively easy way to test it might be to slice it with Slic3r which allows for a different outermost perimeter speed if I remember correctly. Setting a very conservative value for the perimeter speed might be close to the effect the suggested extension might have.
Personally, I like that outermost layer speed feature of Slic3r. It gives the print a very nice and smooth look without slowing down the print too much. Maybe a minimum perimeter time would lead to a similar effect?
gr5 1,967
I think before Daid would add this feature you have to convince him it is needed. You don't use the dual fans of the UM2 (or even single fan of UM1) so you might be a special case.
