All the wires for the sensor board are proprelly connected (on the sensor board and behind the print head). There is nothing close to the printer that could affect the radio frequency. The firmware version is 6.5.1 (latest is 6.5.2, i will update it but i doubt that is the source of the probleme).
When i perform the leveling sensor test, it fails with ER45.
If theres nothing else i can check then I guess the only option left is to call my reseller and ship them the printer.
Thank you
gr5 2,210
If it gets the error before the nozzle touches the glass then the sensor is failing. Check the 2 wires inside the print head that go to the sensor board. When you open the front of the print head, the sensor board swings down with it. Check those wires (very gently tug). Also keep radio frequency noise sources at least a meter away from the printer (e.g. cell phones, microwaves, laptops, raspberry pi's, electric motors).
Do you have the latest firmware? A year or two ago UM improved the leveling software.
There is also a leveling sensor test in the maintenance menu. If it passes, test it a few times. If it fails there then that is good as the problem isn't intermittent and you can experiment.
Talk to your reseller - they might know much more than me.
