5.2.16 was installed. I updated to 5.3.0 now. Still the same Error. Even if I disable the AUto-Leveling and do it manually, the printer is starting to print with a distance of about 3mm to the bed.
I also tried some other print files. Even older Ones which have been printed correctly some months ago, fail now.
Any other ideas?
1) It's possible it's a cura issue. Please post your project file which contains your model and printer settings and profile and overrides. To do this in Cura do "file" "save project as..." and post that file here. I'm thinking this is the most likely issue.
2) Is the problem happening on the left core or the right? If the problem is only on the right core then maybe you have to recalibrate the "lift switch".
3) When doing manual calibration, try calibrating such that things are extra tight against the calibration card. Basically I'm just wondering if you are doing the manual calibration wrong (in addition to something wrong with your active calibration when manual calibration is off).
4) filament doesn't stick to blue tape nearly as well as after you clean it briefly with rubbing alcohol (isopropyl alcohol). Just a few quick wipes with a tissue wetted with IPA.
5) There is a "factory reset" feature in the UM3 maintenance menu somewhere. This may fix the issue but you will have to recalibrate the lift switch and the bed leveling and any XY leveling (XY you can skip for now as you figure out your issue).
Sounds very similar to another thread:
Can you send me all your log files? Send them to me through this forum. Click my avatar, and then on my personal page you see a 'message' button on top of the page.
CarloK 204
What firmware is your printer running? v5.2.17 from a few months ago fixed some of the leveling problems.
