@cheuschober: A minor but often overlooked problem with PETG is moisture.
At lower temperatures the material doesn't have low enough viscosity to flow properly, leading to underextrusion. At higher print temperature, you basically start to degrade the material. This degradation is (very) moisture dependent.
The effects that you describe are related to degradation. Why?
Degradation means that you polymer chains get broken, leading to shorter polymers which have lower viscosity. This means the material will be more liquid-like at those printing temperatures, leading to more severe stringing and oozing.
My first suggestion therefore would be to dry your material in a PrintDry / Oven / food dessicator at 50-70C for a few hours / overnight. Then try to print your model again.
If this is the issue, consider purchasing a PrintDry/Polybox other storage unit to keep your material dry during printing.
Hope this helps!
2
gr5 2,210
Please include photos of what you are talking about. We can't tell if you are complaining about things that are too small/minor to be fixed, if you are on the edge of fixable or if your issue is 10X worse than normal printing.
