UlrichC-DE 123
Info: Normally, the printers only work between 15 and 32 degrees Celsius
59 - 89.6°F
You will probably have to warm up the printer to be able to print. 30F is extreme.
Right, butane in the van is bad. Can you leave the car running for a while or put the printer somewhere else?
I would use an electric heater.
UlrichC-DE 123
Hello
I have also had this error. I have it on the UM2 when it gets too cold. I have never changed the sensor because of this.
Warm it up a bit and print it. With the cover in the front and the top I turn on the heating plate a little. When it prints, it runs through and then has the error at the end of printing.
For me, it was 35F last time.
sensebellum 2
Thank you for the tip! Is there a way to bypass the screen and turn on the heating elements? I tried the scroll wheel but it seemed stuck on that warning. (I'll take a picture this evening).
Aside from that would a coffee warming plate or something work? I was about to stick my butane burner in there but decided against...
Thank you!
