3 hours ago, 43915 said:So you should be able to use it with Cura since there are profiles for it made by Ultimaker.
Just a small note, these configurations are provided by the community, not by Ultimaker. Ultimaker can't test all the hundreds of different printer models. Every user can add new printers, or add improvements to existing printers, on Github.
If I open Cura and click to add a new printer and check the list under "Add a non-networked printer" there's a row for Snapmaker, where Snapmaker 2 A150/250/350 is available when you expand it. So you should be able to use it with Cura since there are profiles for it made by Ultimaker.
Since the Snapmaker has a WIFI connection you might be able to just connect the printer to your computer and go to "Settings > Printer > Add a printer" in Cura and see if it appears in the list. If not you can add it manually like I described above.
