GregValiant 1,492
OK @CarloK I don't know that I understand any better but I'll this a shot.
The OBJ file is just a model and it would need to be sliced in Cura so Cura could create a gcode file (that would have extrusions) that the printer can read. The UFP file (I think) has Gcode information in it that some printers can read, but I think it is specific to Ultimaker printers(????).
Whatever printer your "community printer" is (Ultimaker, Creality, Monoprice, whatever) would need it's definition installed in Cura as your active printer so that the gcode is compatible. Then you can copy the gcode file to an SD card (or maybe a mini SD card) and the printer will read it from there.
Trying to print a file that was created for a different printer is never a good idea. In some cases it works, in others it doesn't work and can make a real mess. If the community printer is an Ultimaker S5 then it could conceivably work. If the community printer is (for example) a Tevo Tornado, then it won't.
CarloK 208
I don't understand the question. Perhaps other people do, then they can jump in.
But, until those more understanding people join, it would be helpful when you could provide more info.
So far I have discovered from your posted files that you have sliced an object for the S5 printer on Cura 4.12.1. This is for the material PLA and you are only using the left extruder.
You also posted an obj-file. Many programs use such an extension. For what kind of program is this file used? Blender?
Please give more details about your problem. What is happening and how would you like to see this different?
