Posted · Ultimaker Original Plus filament stuck in Hot End Isolator Coupler/tube
I have an ultimaker original plus that has something PLA filament stuck in the hot end isolator coupler and hot end isolator tube. I tried heating it up using the heating block. I tried soaking it in boiling water. I tried dripping some acetone into it but I can't get it unstuck.
I'm in the US and I can't find any replacement parts that will ship to my location. Is there something else I can do or place I can find a replacement part?
Thanks,
Audrey
    The PTFE hotend isolator part has a tendency to deform over time, especially if you print with "hot" or temperature conductive materials. Once it does, it will cause blockages, and it should be replaced.
    I think you can still find replacement PTFE parts from chinese manufacturers on aliexpress.
    • 1 month later...
