GregValiant 956
@tinkergnome is correct (as usual). Within the menus of your printer will be "Control | Motion | Steps/mm" and you can enter new values there. They will be temporary until you use "Save Settings". You could also send (or put into a gcode file) "M92 X?? Y?? Z?? E??" to change one or more of the axes. Use M500 to save settings.
An error of .1mm across a model indicates .05mm / side. That is about 1/2 of a human hair. The Steps/mm on the XYZ are very accurate and you shouldn't need to change them (the E is a different story). To handle your dimensional problem you can adjust the Horizontal Expansion in Cura or increase the flow by a couple of percent. If you cool the part the dimensions will get smaller and if you heat the part the dimensions will get bigger. It's plastic.
tinkergnome 923
Those things are not part of the slicing process - the firmware of the printer handles it on its own.
The slicing engine of Ultimaker Cura does not know or need this information - that's why it is not there.
I'm pretty sure, Creality printers are equipped with Marlin-Firmware by default - so it should to be to find somewhere in the printers own settings menu.
Good luck!
