multicolor print with s5 pro bundle
yud
Posted · multicolor print with s5 pro bundle
hi, I have the s5 pro bundle and I wanted to ask if there is a way to use more then 2 colors in one print.
I want to make multi color parts and take advantage of my material station. Is there a script that I need to add to the g-code?
I tried to understand what g-code command is responsible for the filament loading but I couldn't find something that looked right.
any help will be great! thanks.
    I am also interested in this. By the sounds of the response of robinmdh in the post linked below. this is possible if hand modifying the G-code. My question then becomes ... What are the G codes used to control the material station ?
