Posted · printing volume differentiation
Hello,
I'm wondering why when in the machine settings I set the maximum width and depth to 206mm the model turns orange only if it's smaller that W:189,7mm D189,9mm ?
When I scale it to max, it goes to 191mm but it's gray.
Also Cura doen't seem to care about its height. I can have a model higher than the maximum printing height and it turns orange and calculates the toolpath.
Do I have to adjust something in the software or at the printer?
Thanks
Achilleas
    If you go to "layer view" you'll probably see the problem illuminarti pointed out.
    Yes you can't see anything because it doesn't calculate anything.
    But seams logical what you say illuminarti.
    I don't know if you model reaches the corners but if the skirt or brim or model touches any of the 4 gray areas where the clips go then it also won't slice it.
    gr5 what do you mean by 4 gray areas?
    The grey areas gr5 refers to are the reserved spaces for the glass plate clips on the UM2. However, given the sizes you're talking about, I presume you don't have a UM2, so you don't get those.
    Yes…original.
          • Heart
        • 4 replies
